Ansys Learning Forum Forums Discuss Simulation Electronics IR2110 gate driver model in ansys simplorer 2022.R1 Reply To: IR2110 gate driver model in ansys simplorer 2022.R1
pradhan.5
Hi MirandaH,
I have just changed the voltmeter "Vg_hi" which was connected with reference to the ground in the in-built example. I have connected across HO and Vs so that I could see pulsating 15V on both LO and HO outputs. The same works with spice simulator like LTspice but here it is not showing as u can see below in attached file. Am I missing something? Kindly suggest.
