Ansys Learning Forum Forums Discuss Simulation Electronics On the coupled analysis of static magnetic field analysis and structural analysi Reply To: On the coupled analysis of static magnetic field analysis and structural analysi
Erik Kostson
We can use solid226 coupled field elements (AZ,UX,UY,UZ dof) with nlgeom on, and the magnetization vector direction will be updated.
(There is no example in the help manual so it is very hard to set this up if you do not have any experience with MAPDL)
Since like in Maxwell we mesh (MAPDL) the air domain around the magnet, we can only have small deformations of the magnet, otherwise air elements will distort too much and solution will fail/stop (due to high element distortion).
If you have very large deformations (structure) then we can not do this.
All the best
Erik
