Ansys Learning Forum Forums Discuss Simulation Electronics I’m designing a dual stator synchronous generator. How can i fix this error? Reply To: I’m designing a dual stator synchronous generator. How can i fix this error?
MirandaH
To define power in Maxwell for achieving positive torque, you should consider the correct setup for the geometry, the excitation, the boundry condition and the the mechanical transient setup. You can open up a RMxprt example, create a Maxwell model and use it as a reference.
