Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Evaporation Model not working. Turbulent Viscosity ratio issue. › Reply To: Evaporation Model not working. Turbulent Viscosity ratio issue.
August 28, 2024 at 5:09 pm
I am using dispersed because I think, we should use it when one fluid is significantly dominant in volume as in my case, liquid is dominent but yes i want to convert 100% liquid to vapor as well (please correct me if I missunderstood).
I used VOF to increase the computation time.Â
I have started simulation with VOF sharp but the results are same. No simulation runs more than 40 - 50 timesteps.
