Ansys Learning Forum Forums Discuss Simulation General Mechanical How to Set Up CPU to avoid machine crash for ANSYS Mechanical? Reply To: How to Set Up CPU to avoid machine crash for ANSYS Mechanical?
mrife
Ok - well as I said first investigate the hardware and see if either the CPU or RAM are overclocked.  If there is a thermal management tool available see if it has a log.  In the meantime post any warnings and errors that are in the Mechanical Solution Information object.
