Ansys Learning Forum Forums Discuss Simulation Fluids Sector Mesh generator Reply To: Sector Mesh generator
Ren
  1. I'm not sure what you mean by "piston movement". Please explain.
  2. Regarding tutorial 1, it uses the sector mesh generator (SMG). Are you saying that you created a geometry, set up the model using the data in the tutorial? I don't see why it should not work.
