Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › How to create a ball joint between two faces? › Reply To: How to create a ball joint between two faces?
mjmiddle
The shafts expand radially because rotation of the shaft is an unconstrained degree of freedom. They may not rotate at all or they may rotate at a large angular velocity, causing them to expand radially. Be sure to constrain that on each shaft, and maybe the results on the rest of the model will make sense.You could do that with a remote displacement, but it may interfere with the frictionless supports if applied to the same faces. Another way: for the general joints, set reference scoping on the shaft side and fix the rotation direction aligned axial with the shaft.
