Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › Force/Moment Reactions at Contact (Weld Seam Evaluation: nominal stress concept) › Reply To: Force/Moment Reactions at Contact (Weld Seam Evaluation: nominal stress concept)
dlooman
Sorry, my mistake.  Could there be an issue with the moment in the top flange?  Is it computed about the centroid of the top flange?  I assume you are using fsum and spoint for this.
