Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › Problem with using multiple Moving Heat Flux ACT in a given simulation › Reply To: Problem with using multiple Moving Heat Flux ACT in a given simulation
Sampat Kumar
Hi Remi,
Can you check the following points ?
1. The start and end times of all three moving heat sources should be correctly defined.
2. The last patch should be “NO” in the second moving heat source.
2. Please ensure that the last moving heat source is set to The first patch is “no,” and the last patch is ”yes.”.
Best Regards,
Sampat
