Ansys Learning Forum Forums Discuss Simulation General Mechanical Force/Moment Reactions at Contact (Weld Seam Evaluation: nominal stress concept) Reply To: Force/Moment Reactions at Contact (Weld Seam Evaluation: nominal stress concept)
georg.gruber
Thanks for the quick reply! Yes you are right, Wb,x,top is the secion modulus of the top flange. The generic equation for a rectangle shape is (width*height^2)/6. However the height of the top flange is only 2mm (see fig. 1, (40-36)/2. –> The top flange AND the bottom flange have a height of 2mm respectively. So in my opinion 26,67mm^3 is the correct section modulus for top flange (and of course also for the bottom flange).
So, still I don't know why I get this unrealisticly high stresses, when summing up sig_y,mean and sig_y :-(
Greetings from Berlin,
Georg
