Ansys Learning Forum Forums Discuss Simulation General Mechanical Difference between “Python Code” and “Scripting” in ANSYS Mechanical Reply To: Difference between “Python Code” and “Scripting” in ANSYS Mechanical
Erik Kostson
It works on 2023 R2 and with 100 and 200 steps it works fine on a standard lapotop so not sure why it crashes at your end -
finally the settings you show (Advanced properties, core nr, etc) are for the solver (not for scripts) and do not have anything to do with the issue you mention as they deal with the solver (so once we solve a model).
As you have posted another post that is similar (https://innovationspace.ansys.com/forum/forums/topic/how-to-set-up-cpu-to-avoid-machine-crash-for-ansys-mechanical/), we will close this one as it is a duplicate and as I have posted a solution for a script that might be useful to others. Perhaps other forum members have some tips why it crashes because it should run fine.
