Ansys Learning Forum Forums Discuss Simulation Photonics Unphysical Plasmonic Results – FDTD Silver spheres and rods Reply To: Unphysical Plasmonic Results – FDTD Silver spheres and rods
Guilin Sun
Silver at this bandwidth is extremely lossy, and needs finer meshes and long simulation time as well as smaller autoshutoff min. Suggestions for improvements are:
1: make sure the TFSF uses uniform mesh at least the mesh size a little smaller than the background automesh;
2: reduce the autoshutoff min to 1e-6, or even smaller such as 1e-8 etc;
3: increase significantly the simulation time and make sure the autoshutoff min terminates the simulation, before the progress reaches 100%.
4: PML, When you use higher mesh accuracy, the mesh size is small, and thus the PML total thickness might be small. Please make sure the PML thickness to be about half wavelength in order to have better absorption. This will need you to increase the number of layers. If the number has reached to 64, you may need to use "Custom PML", and borrow the PML parameters you are currently using. In addition, you can estimate the largest scattering angle. If it is large say to 70 deg, you may need to use "steep angle PML" with sufficient thickness.
Make sure PML is in the uniform mesh region.
5: please check the material fitting, with smaller tolerance and check if there is any artifical peaks.  Tips for improving the quality of optical material fits
Please note that, the  ".125 min" (I guess it is in nm, not um) mesh size is the mini limit of the mesh size to avoid accidently using too small mesh size. You can modify it if you need smaller size than it.
