Ansys Learning Forum Forums Discuss Simulation Electronics I’m designing a dual stator synchronous generator. How can i fix this error? Reply To: I’m designing a dual stator synchronous generator. How can i fix this error?
Miranda Hourihan
To speed up meshing in Maxwell transient simulation, you can consider the following techniques:
1. Simplify the model where possible to reduce the complexity of the mesh. This can be done by hiding objects that are not essential for the simulation or by combining bodies into multibody parts even if they are not touching, as this will reduce the number of parts to be processed.
2. Use advanced mesh operations techniques to improve the mesh quality. For example, in areas where the mesh creates bad quality tetrahedra, you can apply specific mesh operations to refine the mesh and improve the element quality
3. Optimize the initial mesh settings. For instance, in the General Tab of the Initial Mesh Settings, you can check TAU and move the slider one step to the right to potentially improve the meshing process
