Ansys Learning Forum Forums Discuss Simulation General Mechanical Difference between “Python Code” and “Scripting” in ANSYS Mechanical Reply To: Difference between “Python Code” and “Scripting” in ANSYS Mechanical
zzhang868
Apologies for the confusion. I use "Scripting" to write Python code that adjusts the "Analysis Settings" to set up 100 time steps. However, whenever it runs through a few steps (around 10, for example) to update the settings, the machine crashes. I'm using a CPU with 240 cores (10 nodes, each with 24 cores). I'm wondering if there's a way to run the scripting without issues. Should I modify any settings to ensure the scripting runs smoothly? Thank you so much!
