Ansys Learning Forum Forums Discuss Simulation General Mechanical Buckling Analysis on a curved panel Reply To: Buckling Analysis on a curved panel
dlooman
Sometimes it is good to run your input in batch mode.  It is easier to find the error messages that way.  When I do that with your input above I see the error:
*** WARNING ***                         CP =       0.109   TIME= 10:53:30
 No valid degree of freedom labels were input.  The D command is
 ignored.
That can be fixed like below:
! D,ALL,, , , , ,, , , , ,UZ
d,all,uz,0
I also saw these warnings during solution:
*** WARNING ***                         CP =       0.266   TIME= 10:53:30
 Node 97 on element 1 is unselected.
That can be fixed with nsel,all before solution.
Your boundary condition at the vertical edges is an axial constraint.  That doesn't seem right.  Check your boundary conditions interactively with /pbc,all,1 and nplot.
