Ansys Learning Forum Forums Discuss Simulation Fluids Multiphase VOF simulation of a rotating capillary tube Reply To: Multiphase VOF simulation of a rotating capillary tube
Moving the wall & moving the fluid (so also moving the wall) should give the same result. What is the tube radius?  What happens if you repeat the model with a 30 degree sector and rotational periodic boundaries?
