Ansys Learning Forum Forums Discuss Simulation Electronics Different value of inductance in Ansys Maxwell and Comsol Multiphysics Reply To: Different value of inductance in Ansys Maxwell and Comsol Multiphysics
MirandaH
Hello, there are many reasons could contribute to different results:
Are the geometry identical in both simulation?
Is that full model or partial model? If partial model is used, did you use any symmetry boundaries? Did you setup symmetry multiplier?
Are the material propertities the same?
Do you have eddy effect on both simulations?
Do you use Litz wire model?
Did the simulation converge in Maxwell?
