Ansys Learning Forum › Forums › Discuss Simulation › Fluids › muddy water › Reply To: muddy water
August 27, 2024 at 1:22 pm
We can model filters. But, you also need to work out scale: do you want to model the pores or the bulk system? Porous media is the most commonly used approach to capture the fluid flow, however there are no built in models to remove the filtered material: but do we need to?Â
