Ansys Learning Forum Forums Discuss Simulation Fluids Error in updating design points in the parameter table Reply To: Error in updating design points in the parameter table
Federico
It could be that you have a false convergence on the first iteration when starting your solution from the previous design points. If the Design Point Initialization is set to From Previously Updated, try to change it to From Current.
In Workbench, click on the Paremeter Set in your project schematic, and chage Design Point Initialization from the Properties tab.
