Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Error in updating design points in the parameter table › Reply To: Error in updating design points in the parameter table
August 27, 2024 at 12:26 pm
Set the Reporting Interval in the Solver panel to 3-5 ish. Depending on how big a change the solution has, and where the initial data came from, the solver may trigger converged state before the bc change alters the solution.Â
