Ansys Learning Forum › Forums › Discuss Simulation › Fluids › A small question about defining UDF names. › Reply To: A small question about defining UDF names.
August 27, 2024 at 9:21 am
Check 26.2.10.2.6 in https://ansyshelp.ansys.com/account/Secured?returnurl=/Views/Secured/corp/v242/en/flu_ug/flu_ug_sec_multiphase_setup.html%23flu_ug_sec_mphase_massxfr and see if an example for DEFINE_MASS_TRANSFER will load OK. It doesn't need to be what you want in the model, it's just to confirm it's the correct macro.
