Ansys Learning Forum Forums Discuss Simulation General Mechanical Gear tooth deformation due to rotational velocity Reply To: Gear tooth deformation due to rotational velocity
sudhakar917
Hi Deepak,
I have used one end fixed support and other end cylindrical support. The total deformation of gear tooth is 90 microns.
I have used journal bearing stiffness and damping properties on both ends (k11,k12,k21,k22, c11,c12,c21,c22). The total deformation is given as 220 microns.
Which one is correct?
Please help me out.
Sudhakara
