Ansys Learning Forum › Forums › Discuss Simulation › Photonics › Method to swap axis (exchange axis) › Reply To: Method to swap axis (exchange axis)
August 26, 2024 at 4:29 pm
Hi Anindya,
You can change the axis by using the rotation tab of the object, after the design is completed:
If the geometry consists of a large number of sub-components that have to be rotated, then you can group them into a structure group, and then rotate the entire structure group:
Amrita
