Ansys Learning Forum Forums Discuss Simulation General Mechanical Problem with using multiple Moving Heat Flux ACT in a given simulation Reply To: Problem with using multiple Moving Heat Flux ACT in a given simulation
remi.gerard-marzan
I have, but there's nothing unusual in that file. It says the same thing for the instance that's failing than for all the others.
Would you know if the ACT creator is still around? Ashutosh Srivastava.
