Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Simulating flow through many small pumping objects › Reply To: Simulating flow through many small pumping objects
August 23, 2024 at 3:36 pm
No worries, the back end team have been doing stuff so it should be better now.Â
It's an option for you to look at. In CFD we can solve most things, but if a mussel opening is 1-2mm across in a domain the size you're looking at the cell count may be rather high. There's also the transient effect - it's an in-out pumping rather than continuous.Â
