Ansys Learning Forum Forums Discuss Simulation Photonics Pockels effect EOM Reply To: Pockels effect EOM
Guilin Sun
I did not find how did you set the voltage so I cannot say what is wrong.
From your screnshot, it shows E does not record the voltage change. To dig it might be difficult. However, you can
1: download the online file and run it. make sure it runs without any issue.
2: then only change the voltage, run it and see if it works/
3: modify the materials and run
4: modify the structure if necessary and run
you need to isolate each test in order to find the root cause.
