Ansys Learning Forum Forums Discuss Simulation Fluids Animation Reply To: Animation
Federico
Seems like you are correct, FPS is limited to 60. In that case, you might have to re-run your simulation and save your animation frames at a rate that accounts for 60 FPS or use a third party software with the data that you already have to modify the speed of the video.
