Ansys Learning Forum Forums Discuss Simulation Fluids Rocky Particle Entry Reply To: Rocky Particle Entry
Guilherme Hanauer de Lima
Hi. Yes, just enable the Random Angle checkbox and set the half range angles. If you want 360 degrees randomization in all directions, you should use 180 degrees in all three directions (x,y, and z) for the half range angles.
