Ansys Learning Forum Forums Discuss Simulation General Mechanical Gear tooth deformation due to rotational velocity Reply To: Gear tooth deformation due to rotational velocity
Deepak
If you give both cylindrical supports, the model won't be in static equilibrium. So, you can fix one end of the shaft (based on your component mounting in top-level assembly) and give cylindrical support to the other end.
Thanks,
Deepak.
