Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Laser Melting heat source UDF issue [FLUENT Crashing] › Reply To: Laser Melting heat source UDF issue [FLUENT Crashing]
August 23, 2024 at 8:40 am
Does it work if you just use C_UDMI = C_T with all of the (c,t) bits? Making up labels that are similar to something Fluent may use can be a little risky.
