randyk
If ANSYS 2024R2  applications work but WB fails with this error:
"Workbench could not connect to a valid licensing server. Review your license configuration in the Ansys Licensing Settings application and make sure you are connected to a valid network"
This would be related to issue 1113708 - Cannot open WB in 2024R2 but standalone applications work fine
Currently, there is no solution.  We are working with developers to obtain the fix.
