Ansys Learning Forum › Forums › Discuss Simulation › Photonics › Pockels effect EOM › Reply To: Pockels effect EOM
Guilin Sun
Unfortunately Forum does not have any other way of coomunications.
Please check that I used 7v while the online example is 5v. I am not sure what happened to your script. Please make sure you only changed the voltage max and number of steps, other than the material. You need to check the dimension of E and see what is wrong there.
 ?dts;
the 2nd dimension is the votage.
compare with the orginal file and find what is changed.
Please write a new post for any issues you have, preferably one post for one type of questions. This post has two different type of questions.
