Ansys Learning Forum Forums Discuss Simulation Fluids Flow Through an Object Inside Enclosure – ANSYS Fluent Reply To: Flow Through an Object Inside Enclosure – ANSYS Fluent
qnp5rg
Hi Rob,
Thank you for that. The domain would be about 2 m by 0.5 m and the bed itself would be around 1 m by 0.5 m, the question I am partially trying to answer is how much of an impact the mussel pumping has on the hydrodynamics and mixing processes. Each mussel outlet would have a velocity of around 1-2 cm/s and I am looking at very slow (less than 5 cm/s) ambient flows.Â
