Ansys Learning Forum Forums Installation and Licensing Ansys Products Multiple License Files in the Same License Server Reply To: Multiple License Files in the Same License Server
operator
Hi Mrunali,
Thank you for your reply! Could you please point me out to a resource indicating how to have 2 license files on the same server? We attempted doing it in two ways, below I focus on a single feature, but the beahavior is the same for more features. License details were redacted from the files for privacy reasons.
1) Two separate license files
In this case we have two files:
# ansyslmd1.lic
SERVER licenses.rcc.local aabbccddeeff 27011
VENDOR ansyslmd port=27012
USE_SERVER
INCREMENT optislang_level3 ansyslmd 9999.9999 04-aug-2025 2 \
AABBCCDD123 VENDOR STRING="customer:111111 tp:a" SUPERSEDE \
ISSUER=SIEBEL ISSUED=09-aug-2022 START=05-aug-2022 SIGN2="XXXX \
XXXX XXXX XXXX XXXX XXXX XXXX XXXX XXXX XXXX XXXX XXXX XXXX \
XXXX XXXX"
And:
# Second file: ansyslm21.lic
VENDOR ansyslmd port=27022
USE_SERVER
INCREMENT optislang_level3 ansyslmd 9999.9999 08-sep-2024 1 \
EEFFGGHHJJ123 VENDOR_STRING="eval customer:222222 tp:a" \
SUPERSEDE ISSUER=SIEBEL ISSUED=19-aug-2024 START=09-aug-2024 \
SIGN="YYYY YYYY YYYY YYYY YYYY YYYY YYYY YYYY YYYY YYYY YYYY \
YYYY YYYY YYYY YYYY YYYY YYYY YYYY YYYY YYYY YYYY YYYY YYYY \
YYYY YYYY YYYY YYYY YYYY YYYY YYYY YYYY"
As you can see, both files have the same feature “optislang_level3”, but the first has 2 seats, and the second has 1 seat. Both are related to different customers, and have different issuance/expiration dates. Restarting the license server with these two files in the license_files directory makes only the second one to be active, e.g., running lmutil lmstat yields:
License server status: 27011@licenses.rcc.local
  License file(s) on licenses.rcc.local: /srv/ansys_inc/shared_files/licensing/license_files/ansyslmd1.lic:/srv/ansys_inc/shared_files/licensing/license_files/ansyslmd2.lic:
licenses.rcc.local: license server UP (MASTER) v11.19.0
Vendor daemon status (on licenses.rcc.local):
ansyslmd: UP v11.19.0
Feature usage info:
Users of optislang_level3:  (Total of 1 license issued;  Total of 0 licenses in use)
2) Merging into a single license file
We have also attempting creating a single license file:
# ansyslmd.lic
USE_SERVER
XXXX XXXX"
But in this case the same happens, only the feature with 1 seat is shown.
If we start the server only with the  AABBCCDD123 license, then it correctly shows the two seats:
Users of optislang_level3:  (Total of 2 licenses issued;  Total of 0 licenses in use)
But then if we append the second license (EEFFGGHHJJ123) and re-read the file and restart the server, what we see in the log is:
9:41:46 (ansyslmd) Feature optislang_level3 superseded by optislang_level3
9:41:46 (ansyslmd) optislang_level3
9:41:46 (ansyslmd) Rereading options file...
9:41:46 (ansyslmd) =====================================================================================
9:41:46 (ansyslmd) ==== Reread : Feature List and Client Validation Initiated ===
9:41:46 (ansyslmd) === ls_client_removal_on_reread is disabled ===
9:41:46 (ansyslmd) Support removed for feature optislang_level3(AABBCCDD123) [FEATURE_REMOVED]
And then only the second license is shown. Is the SUPERSEDE option at play here? Can we just remove that?
Looking forward to any recommendations.
Thank you,
Gustavo
