Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Flow Through an Object Inside Enclosure – ANSYS Fluent › Reply To: Flow Through an Object Inside Enclosure – ANSYS Fluent
It's the "Combine" tool. It'll be covered in the tutorials under Help on the software. You'll need to check how it handles multiple objects, I think it's a case of clicking each one but I tend to focus more on the solver side.
How big a domain are you looking at? Ie is the mussel pumping sufficient to do much?
