Ansys Learning Forum Forums Discuss Simulation Fluids Set number of cores in System Couping standalone. Reply To: Set number of cores in System Couping standalone.
Federico
Hello Lukas,
you can set up the Parallel Partitioning as follows:
Under Participant Weights, specify the resource weighting for each coupling participant as a real number.
