Ansys Learning Forum Forums Discuss Simulation Fluids RGP Tables exceeding ranges when switching to RPI model Reply To: RGP Tables exceeding ranges when switching to RPI model
zain.qazi
The velocity is increasing at a reducing rate from 5 to 40 m/s between the inlet and outlet. High pressure is seen at the inlet around 30 bar and drops to 21 bar at the outlet. The temperature stays more or less constant in the core region. Near the wall it rises to 140 K but is around 80 K in the flow away from the wall. Should increase when the simulation progresses.
