Ansys Learning Forum Forums Discuss Simulation Fluids ERRO WHEN TRYING TO WRITE A .TXT FILE USING UDF Reply To: ERRO WHEN TRYING TO WRITE A .TXT FILE USING UDF
The error means it's not compiled, so you need to resolve that before loading the library. What error are you seeing when compiling?
Are you wanting the data at a single instance, ie the end of a solution or during? I ask as surface reports may be an easier approach.
