Ansys Learning Forum Forums Discuss Simulation Fluids circulation of hot dry air through colder soil Reply To: circulation of hot dry air through colder soil
Higher flow will mean a higher HTC (usually) but also more mass to carry heat away. If the domain is sealed (ie adiabatic surrounds) then the temperature should reach the same value eventually as the heat can't go anywhere.Â
