Ansys Learning Forum Forums Discuss Simulation Fluids RGP Tables exceeding ranges when switching to RPI model Reply To: RGP Tables exceeding ranges when switching to RPI model
Look carefully at the flow as the divergence approaches. Whilst some of the boiling models are allegedly steady state the resulting multiphase flow usually isn't.
Also, whilst the mesh has y+>30 how does the aspect ratio look? It's a failing in most of the text books: everyone is told about cell aspect ratio, but then doesn't realise that inflated meshes always have a high aspect ratio. That's OK if the solution doesn't change along the cell; this never happens in multiphase.....
