Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › Set up time steps more efficiently › Reply To: Set up time steps more efficiently
August 22, 2024 at 3:31 am
mjmiddle
Sorry, but free ACT extensions are not supported and I don't have great expertise with this extension. There is a doc file inside the download that contains a pdf file for instructions on how to use the extension. You can edit the extension's python file for your own needs.
Yes, it was last updated for Ansys 19.0 so may not work correctly in newer versions.
