Ansys Learning Forum Forums Discuss Simulation Fluids Animation Reply To: Animation
Federico
Hello Sanil,
Once you have your animation ready, in the Playback dialog box, you can adjust the Video Options and set the frame rate (FPS) to match your desired video durantion. FPS is frames per second, so for 500 frames in 5 secods, your should set the FPS to 100.
I hope this helps.
