Ansys Learning Forum › Forums › Discuss Simulation › Fluids › RGP Tables exceeding ranges when switching to RPI model › Reply To: RGP Tables exceeding ranges when switching to RPI model
August 21, 2024 at 2:59 pm
zain.qazi
Found in the User Guide that using a single phase solution as the starting point for a Eulerian is not the way to go (p 3166). Will attempt setting up a Mixture Model Case first and using that as the initial solution.Â
