Ansys Learning Forum Forums Discuss Simulation Fluids muddy water Reply To: muddy water
No, it's a way of modelling a contaminated material without needing to try and track the phase. Species models can also be used, as can scalars (I've seen work on sedimentation tanks using that approach). You need to review the porous model in some detail to understand what it does, and also what mechanism you're using to clean the water.
