Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › Set up time steps more efficiently › Reply To: Set up time steps more efficiently
mjmiddle
Not really if you have multiple load steps, and it sounds like the reason you want to do this is because you have a large amount of load steps. You would need to completely replace all the time stepping and solve commands in APDL. You could use a *DO loop for this. This will overide all the solve commands that Mechanical writes for each load step and could really mess things up with your loading for any loading that changes between load steps, such as activation state of loads/supports. You are better setting up the load steps in Mechanical not APDL. Check out the "Analysis Settings Importer" extension in the ACT Store:
https://catalog.ansys.com
