Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › Set up time steps more efficiently › Reply To: Set up time steps more efficiently
zzhang868
Thanks! I am wondering if it’s possible to use APDL to set up "Analysis Settings" directly, instead of manually entering the "Number of Steps" and "Step End Time" in the GUI. When dealing with many time steps, setting up the "Step End Time" for each step manually can be time-consuming. If it is doable, could you please share a detailed procedure to avoid any conflicts between the GUI and APDL?
