Ansys Learning Forum Forums Discuss Simulation General Mechanical Change Material Property Reply To: Change Material Property
zzhang868
Thank you so much! If I have many parts, for example, 100 identical parts, but with different material properties, how can I use APDL to assign new materials to each part more effectively? In the current example, we only have two parts, but what if the number of parts is much larger? Can we still use a single APDL to change materials for all parts?
