Ansys Learning Forum › Forums › Installation and Licensing › Ansys Products › Workbench license error › Reply To: Workbench license error
August 20, 2024 at 7:45 pm
Hi Lisa,
The issue is most likely the 'ansyslmd.ini' file in your ANSYS WB folder is not correct - whereas your Electronics is.
Rather than dealing with multiple 'ansyslmd.ini' files, I prefer to add these two environment variables:
ANSYSLMD_LICENSE_FILE=1055@(your license server host name)
ANS_FLEXLM_DISABLE_DEFLICPATH=1
The 'ANSYSLMD_LICENSE_FILE' will point all ANSYS applications to your license server.
The 'ANS_FLEXLM_DISABLE_DEFLICPATH' will tell ANSYS applications to ignore the respective ansyslmd.ini file(s).
thanks
Randy
