Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › laminated composite stiffened plate/stiffened panels › Reply To: laminated composite stiffened plate/stiffened panels
Govindan Nagappan
Check the contact definition. Is this a shell model? then, make sure blue and the red faces see each other. You can use the setting "contact shell face" or "target shell face" and switch to top or bottom side.
See if you can use a different contact algorithm. Try MPC instead of the default algorithm.
