Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › Unusual high tensile stress on bolt just below yield strength › Reply To: Unusual high tensile stress on bolt just below yield strength
Deepak
Review the bolt material properties and ensure they are accurately defined in your model. Additionally, how you model the bolt and preload can significantly affect the simulation results. Proper modeling and analysis of bolted connections, including the consideration of bolt preload effects, are crucial for evaluating the structural integrity of assemblies. Make sure that the pretension load is at the middle of the shank, by scoping the geometry properly. Please cross-check the bolt preload calculations based on standard procedure.
Please refer to the Ansys courses on bolt pretension: Modeling the Bolt and Preload | Ansys Innovation Courses| Connecting Bolts with the Rest of an Assembly | Ansys Courses| Preloaded Bolted Joint Analysis | Ansys Innovation Courses.
Thanks
Deepak.
